miss at low rpm????
Old Sep 8, 2001 | 04:51 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
miss at low rpm????
getting ready to take this thing to the track i fire it up and make one last check that nothing is leaking and everything is working. i go gas up and when i tryed starting it at the station, the starter lugged bad, as if it was really advanced or the battery was dead. finally it starts and i get it home. shut it off and same thing. checked timing, checked battery condition, starter is good. if i let it cool it starts fine, so 15min later i fire it back up and suddenly the engine develops a miss at idle.
It's a consistant miss but im pretty sure all 8 fire.. if i rev it above 1500 it runs smooth. driving it like this causes the car to shake badly and taking off it sputters and misses until 1500+ where it runs normally.
what the-!?
i don't know if the two things are connected..
does anyone have any idea whats going on??
PS-i thought maybe the alternator is going bad, but i just got it bench tested and it's still strong.
Camaro nut in training.
1982 Camaro Z28
"non performance"
Vortec 350/700r4
3.73's with powertrax locker
1984 Camaro Z28
(parts)
1985 Camaro Z28
305/700r4
stock
Old Sep 8, 2001 | 11:01 PM
breathment's Avatar
ignition moduel?? has sort of a low and high RPM mode, you can bring it somewhere to have it tested.. but the more that i think of it, it sounds like a vacumm leak, do u have a vacume tester? is it carbed or TPI?
i got to be right one of these times
Old Sep 8, 2001 | 11:20 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
if you have a carb. the idel circuts in the stock rochester were made to be very lean. if you pick up the book by doug roe it shows you how to get a better idel.
Old Sep 9, 2001 | 12:54 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
Yup you were
it was a dang vaccum leak
****ty how something so small threw off my whole racing plans for the weekend
shoulda had my eyes more open this morning, coulda went if i had caught that earlier.
thanks for your help guys.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
