refuses to idle
Old Jun 19, 2005 | 07:35 PM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
refuses to idle
i posted this in the cooling section and that got me no answers at all. the only thing i can think of is bumping (reposting) to this board.
my battery wasnt taking a charge so i go a second battery and charged them both in series to fix it. after a few hours my original battery was about 3/4 charged. i installed it in the car and let the car idle to try and fully charge the battery.
i left it and went to mcdonalds and was gone for about a half hour or so. i came back and i noticed it was no longer running. i popped the hood to find steam and my overflow tank boiling and my belt running from my crank to alternator and water pump crammed against the passenger side shock tower. the temp gage in the car was pegging as far as it could.
the car turns over with the key. the water pump can turn by hand. i got a new belt and tried starting it and it does not stay started for more than 2 seconds.
i have a few questions:
this is exactly what i found. can someone tell me why the car stopped running? i realize it got extremely hot and stopped, but what causes the engine to shut down. tolerances close up or something?
my next question is why was the coolant boiling? is this because the pump stopped pumping coolant through the rad?
what could i have possibly destroyed/damaged (why won't it idle)
and finally if i boil my coolant like i did, will it distill the water out of the coolant, so i have only coolant in the car, or do i have to add my mix of coolant and water.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
