L98 question
Old Jun 20, 2005 | 10:08 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
L98 question
Finally started "looking into" the L98 I pulled out of my red IROC. I already know its not the original engine so no surprise there. However, when I pulled the oil pan it has 4 bolt main bearing caps. It has the one piece rear main, the one piece oil pan gasket, the center bolt valve cover heads (I still need to check to see if it has the roller cam - didn't do that yet). Did the L98 's have 4 bolt main bearing caps?? Thanks.
Old Jun 20, 2005 | 10:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A Corvette L98 would, an F-body L98 would not have 4 bolt mains. A replacement, crate, or 'service' engine would also have 4-bolt mains though.
Old Jun 20, 2005 | 10:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
It's likely a truck block or a GM goodwrench motor. Why not just get the casting numbers and look them up?
Old Jun 20, 2005 | 10:49 PM
Z's r Best's Avatar
Thanks. It's got the iron heads so at least they didn't come off a vette. I'll pull a valve cover and get the number off the heads, too. Is there a place on this site to check the numbers. Just found them on a piece of box cardboard from a couple of months back (wrote them down, didn't find them in my SBC interchange guide book and then forgot to investigate further).
Old Jun 20, 2005 | 11:18 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
www.mortec.com. Drections and look-up onsite.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
