Vacuum Ball under Canister
Old Jun 20, 2005 | 11:24 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
hey guys! i converted to carb from tpi and now i was wondering if i can use the ball that is normally for the CC to run my power brakes? would that be ok or is the ball not good enough for the brakes? thanks.
Old Jun 21, 2005 | 09:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ball doesn't "run" the power brakes.
All it does, is accumulate enough vacuum to work the A/C and heater doors in the interior, and the cruise control, while engine vacuum is low (like when you floor it).
Hook your power brake line to the plenum.
Old Jun 21, 2005 | 09:32 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
And the "correct" name for that reservoir on TGO is "Orb of Power"
Old Jun 21, 2005 | 03:29 PM
Kevs87Z28's Avatar
Engine: 355 Carb
i dont have a plenium didnt you read what i said at all? i said can i use it to run the power brakes not does it run the brakes. and i said swapped from tpi TO carb not the other way around.
oh and excuse me the "orb of power" can it hold vacuum for the brakes?
Old Jun 21, 2005 | 03:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, it can't.
Hook the power brake vacuum line to a plenum source, rather than a runner source.
(Yes, we did read what you said.)
Old Jun 21, 2005 | 09:53 PM
Kevs87Z28's Avatar
Engine: 355 Carb
alrighty then. didnt sound like you understood what i said. i have an edelbrock RPM AIR Gap manifold and a 650 DP. im getting like 14" of vacuum at idle off of the hole i elbowed off on the manifold that is normally under the secondary bowls but i put a spacer on it to get under there.
so i just need a canister then. why the heck do they call it a vacuum reserve ball if it cant hold vacuum. eh what can ya do right? oh well thanks anyway
Old Jun 22, 2005 | 09:46 AM
kevinc's Avatar
Car: 1982 Z28
Wow, you've invented a carb intake with no plenum?? That's amazing!!
(because every single and dual-carb intake commercially available has a plenum)
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
