need serpentine conversion help
Old Sep 9, 2001 | 09:01 PM
MarkS's Avatar
I'm doing the serpentine belt conversion on my 84 (LG4). I got all the brackets and pulleys from an 89 Caprice 350 TBI. Now I need to find an A/C Compressor. Does anyone know if I need to get a caprice compressor or will almost any serpentine compressor do? I can pick up a compressor from a truck or van for not too much money. I'm mainly worried about the pulley not lining up with the rest of my setup. Thanks in advance.
Old Sep 10, 2001 | 05:55 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Just about any serpentine compressor should work. The R-4 compressor bodies are all just about the same, its the pullies that are different, and it if has the serpentine pulley on it, it should work.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 10, 2001 | 08:56 AM
MarkS's Avatar
Thank you!!!
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
