I've been wanting some time to put my action+ back into action. It's got a hairline crack next to the water outlet and when you rev up the engine it leaks antifreeze. Ive tryed aluminum seal but it dident work, Ive heard theres some welding rod for aluminum but I cant get any localy and if I was to order it I would have to get a bulk. A pack of the stuff is as much as a new manifold
. IMO jbweld is the ony option but I havent has any luck with the stuff on other items. I hate to waste an otherwise good manifold.
SSC
2nd manifold swap of the day if jbweld should work so please reply.
. IMO jbweld is the ony option but I havent has any luck with the stuff on other items. I hate to waste an otherwise good manifold.SSC
I'm not sure if it would work, but what about Permatex. My brother put that on my valve cover gaskets and around my thermostat.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
five7kid
close
Go ahead and use it. You've got nothing to lose but a set of gaskets and your time.
Clean the surfaces very, very well before you try it or it won't stick. I like brake cleaner - a good solvent and it evaporates quickly and cleanly.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
I imagine the permatex would probably work, but why "band-aid" when you could fix it right for just a little more dough? I would take it to a local welding shop and have them TIG weld the crack. Chances are they will only charge you $10 or $15 maybe even less. Plus it will be a professional weld.
Doing this will keep you from worrying about the possibility of blowing out the permatex. That might never happen, but with it fixed the right way is good peace of mind and one less thing to worry about.
Thanks for the replys guys!
I Jb welded it, both sides and sanded the outside down then painted it with 1406 aluminum paint. It looks real nice except for the little cottage cheese spot from the JB.
I pulled off the old manifold "82 firbird LG4" and compared the two. Man did GM make a ****up with that one. The l69manifold that was on my camaro was far supereior than the LG4 except the LG4 is aluminum and the L69 was cast. But the action+ will be on tomorrow and I can toss the adaptor plate
Side note: I took off the stealth manifold on my truck and replaced it with an Xcellerator today.
That sucker pulls until 7200k now
This might give ya cowl guys another option, the stealth petered out at 6400.
Also I tryed the stealth halfA$$ on the bird and the air cleaner would not clear the hood. This is the sole reason I got a cowl for my camaro, I dont know how you guys did this with a stock hood but more power to you.
Ok so I'll have the action+ bolted down tomorrow and running. I'll let you all know if it worked.
Thanks again!
SSC
[This message has been edited by SSC (edited September 11, 2001).]
.Side note: I took off the stealth manifold on my truck and replaced it with an Xcellerator today.
!This might give ya cowl guys another option, the stealth petered out at 6400.
Thanks again!
SSC
shouldn't be hard or very costly to have welded. any more about every one has a tig or mig welder set up that could fix it for you and it'd be better than taking a chance on the jb not working.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Well I finaly got done about an hour ago and went for a long drive. The JBweld held great but unfourtanetly I needed new valve cover gaskets
and since I hate the standard bolts on the valve covers I got some Y bolts and they make life soooooo much easyer.
As far as the swap is concerned I dident gain squat over the stock manifold/adapter plate, Its just a little more peppy on the bottem.
IMO this swap wasent worth the time/money, but it does look nice.
SSC
EDIT: I checked the vac and whoo gained 1 whole inch of vac at idle
for a grand total of 12/13 in nutral, in gear/550/600rpm 7/8.
I guess i'll recoup lost money with the gas I'll save in 3 years. lol.
SSC
[This message has been edited by SSC (edited September 10, 2001).]
and since I hate the standard bolts on the valve covers I got some Y bolts and they make life soooooo much easyer.As far as the swap is concerned I dident gain squat over the stock manifold/adapter plate, Its just a little more peppy on the bottem.
SSC
for a grand total of 12/13 in nutral, in gear/550/600rpm 7/8.I guess i'll recoup lost money with the gas I'll save in 3 years. lol.
SSC
There's a thing on exhaust manifold repair in this month's issue of Super Chevy (what a rag!). It's made by "RestoMotive Laboratories", and it's called the "Manifold Restoration Kit". Like I said, it's for exhaust manifolds, but they might have something for aluminum. I think your manifold is aluminum, I don't remember. Anyways, you can read about it on www.por15.com.
No guts, no glory.
No guts, no glory.
