Oil Filter and Tools
I bought a K&N oil filter for my car and spoke with a mechanic afterwards. He said that it's a waste of money (I have a v6 no mods). What do you guys think? Also, I've recently moved so now I have sort of a driveway to work on my car. Any suggestions on basic tools I can buy to do basic car maintenance? Thanks.
Kevin
Kevin
Car: 1985 Trans Am
Axle/Gears: 3.70
Yes the expensive oil filter was a waste of money. Just stick to the Delco's for $2.50 a peice. For maybe the slight increase in protection it's not worth the ridiculous price increase. The K&N air filter is worth it at least in the fact you can clean and reuse it.
As for tools, get yourself a good socket set with both standard and metric sockets our cars use both quite a bit. Make sure it has 1/4", 3/8" and 1/2" drives. Mutli-meter is nice to have for any electrical related problems. Some box wrenchs, pliers, side cutters, needlenose pliers. Just your basic hand tools.
1985 ASCD Ram Air Trans Am
Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
" I get drunk, I race cars and I fondle women. But... I have weekends off and I am my own boss"
Transmission: 4L80E/4L80E
For oil changes, you'll need portable ramps, or a floor jack and jack stands to get the car up high enough to get under it to do the oil change; a pan to catch the oil as it drains out and a container to take it to the recycle center (Checker takes mine); and an oil filter wrench to fit your filter (and hand tools to remove the drain plug). There are several kinds of filter wrenches, from a metal strap, to a cap that fits the flutes on the bottom of the filter, to a web strap on a square bar that you turn with a ratchet. I have all three. Only the web strap is a "univeral" size, the others have to match your oil filter.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 2002 Camaro SS
Transmission: 6 speed
Axle/Gears: GM 3.42
instead of ramps you can be real ghetto and use a few 2x4s stacked up to drive the front wheels onto. just make sure there's no nails sticking up!
1992 25th Anniversary z28 Convertible
i agree with the above. you can buy a cheap filter and change it more often if you are concerned and still save money. you can buy a cheap floor jack but if you want to work on anything else or frequently i would get a larger jack. not those tiny little ones they call floor jacks. i got one as sears for like 100.00 and another at a wholesale place for 60.00 they work equally good. as for tools. buy a manual for your car. it does have some good information in it 20 bucks i think and i would reccomend a basic tool set from sears they are good quality and lifetime warranty`you can get a decent set for around 100 bucks i think.
you can get cheap tools for 10 bucks but you get what you pay for. a good set of tools is a life long investment if you can spare the money.
thats just my $.02
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake hooker long tube headers mufflex 4"exhaust accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
thats just my $.02
Hotrodboba400
Dec 10, 2019 07:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
