BELTS are killing me!
Old Sep 10, 2001 | 07:15 PM
johnyIROC's Avatar
I have an '83 355 in my car with v-belts. No matter what I do, it launches the fan belt at 5,000 RPM. I have replaced the crank pulley, the waterpump, the waterpump pulley, and gotten new belts... nothing seems to work!
I am ready to take my car to the track, but I have to get this figured out.
johnyIROC 1983 Z28
"5.0 is way too slow"
Old Sep 10, 2001 | 07:38 PM
90Form350's Avatar
Maybe the belt is too tight?
1990 Pontiac Formula 350
Rebuilt 355
COMPCAMS 212/212 .440/.440 cam
Flowmasters 80 series.
Old Sep 10, 2001 | 09:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You need "Z" rated belts... J/K!
I didn't like my belts either, so I converted to Serpentine Belt and it seems so much smoother, no thrown or rolled belts, and is easier to replace a component.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 10, 2001 | 09:22 PM
johnyIROC's Avatar
I want to convert to serpentine, but I have an older engine, so I don't think I can just rob the pulleys from the boneyard and throw it together can I?
Old Sep 10, 2001 | 09:31 PM
johnyIROC's Avatar
I repositioned the alternator bracket... I think the belt is going to stay on now... but I still want to convert to serpentine in the future... here's a pic of my pulleys now:
johnyIROC 1983 Z28
Old Sep 10, 2001 | 10:35 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I bet I have spent over $70 on belts this week. My car would shoot them off at 6000 rpm. Just today I bought 4 belts for this thing to get this straitened out. I used string to get everything lined up but still it threw them off. I was at the carwash today putting a belt back on and a friend told me that I should try one of those belts that is smooth on the inside instead of having the ridges. Anyway, it is called a top cog belt. The ridges are on top instead of on the bottom.
The one that I used came from Advance Auto Parts and the brand is "Dayco". The "Dayco Top Cog Belt" has a part number on it that represents the size.
Just take a string and go around the alternator, water pump, and crank. Then measure it. Mine was 47 inches because I use a big deep groove racing pulley. The part number for instance was 15470. The 15 is the thickness. (15/32) The 470 means 47 inches long.
I raced several times tonight and it hit 6500 rpm numerous times. It's still there. The others would either come off or spin upside down on the pulleys. Hope this helps.
Old Sep 11, 2001 | 06:02 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you have V-belt mounted accessories, then there is no reason why you shouldn't be able to convert to serpentine.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
