'92 Camero running hot
Old Sep 12, 2001 | 03:36 AM
rendabot's Avatar
l
[This message has been edited by rendabot (edited September 13, 2001).]
Old Sep 12, 2001 | 08:25 AM
82camaro's Avatar
Car: 82 camaro SC
If you can't spell camaro, I can't help you. Some more info about your car would be helpfull once you get the spelling figured out.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
