Car won't run with IAC connector off for adjustment? NEED HELP FAST!
Old Sep 12, 2001 | 03:08 PM
BrianB's Avatar
I did everything it says to do but the car won't run with the connector off, you can keep it running by revving it up, but as soon as you let off it dies. What gives? By the way I am attempting to adjust the IAC.
Old Sep 12, 2001 | 05:46 PM
DSouthern's Avatar
Have you made any modifications to your engine or is it stock?
What I had to do to keep the engine running after unplugging the IAC was either adjust the throttle stop screw out a little to increase the idle speed or use a small washer/spacer between the throttle and the stop screw to keep the engine running until I could adjust the throttle stop screw.
Once you get the idle speed set, you need to check the Throttle position sensor voltage to make sure it is within specification.
87 GTA, 350 TPI, auto, 3:27 gears, rebuilt engine, ZZ3 cam and valve springs, pocket ported stock heads, edelbrock intake, TPIS air foil, AFPR, high flow air cleaner, modified stock air canister, tb bypass, ported plenum, modified MAF (screens removed), edelbrock headers, hi-flo cat, flowmaster muffler, stock chip.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
specialized
Jun 18, 2022 09:26 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
