holley stealth ram or high-flow tpi??
Old Jun 27, 2005 | 12:56 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
i have a 2wd 1992 chevy fullsize with a mildly built 355 TPI "91 z28" 212-218 264-270 487-495 110 comp cam, comp cam 1.52 roller tip rockers, 24lbs, afpr, hypert flat tops, stock heads for now......exhaust......i have a edelbrock base, ported slps, ported plenum, and a bbk 52mm, sitin in the garage, what would make more power and be better for my trcuk my high-flow ported TPI setup or a holley stealth ram setup? i have a 2200 stall and a built 700r4 to back it up!! so what do you all think??
Old Jun 27, 2005 | 02:18 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Im not very familiar with the setups youre describing.....got any numbers? As far as intake size, intended powerband, etc?
Sounds like youve got a pretty nice setup for a truck....just a bit wild, but still torquey enough for good streetability... The TPI setup will probably work well....but then I dont know the specs on a Stealth Ram...
Old Jun 27, 2005 | 08:02 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
you'll make more top end with the hsr. thing is... your cam looks better suited for high-flow tpi. it's a small cam, but the hsr makes more power with ported/aftermarket heads and cam (and a higher stall converter as well). i wouldn't waste my money on the highflow tpi though... to me, it's not worth it. i was thinking the same thing you were, so isntead, i bought aftermarket heads, bigger cam (224/230), 1.6 rockers and a 3000 stall converter.
if you really want to go with one or the other and waste some money, go with the high-flow setup.
but may i suggest spending the money on a nitrous kit? depending on your cr, a 100-150 shot nitrous kit sounds a lot better than throwing away your money on a high-flow tpi setup. get all the goodies so that you never experience a problem with nitrous. u should seriously look into it... hope i helped some...
Old Jun 27, 2005 | 07:49 PM
Car: 92 1500p\u 2wd
well im a few steps ahead of ya , i have a full nx kit, purge, wot switch, fuel sayfey switch, rev limiter........and i have the high-flow setup now its just sittin, i was just thinkin that if it would be better to go with a hlley or somthin like that then i was goin to sell my kit and get somthin else.
Old Jun 27, 2005 | 08:53 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
like i said...for the hsr to shine, you need aftermarket heads, good cam, and a high stall (higher than what you have).
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
