Where can I get new plastic fan switch connector???
Old Jun 29, 2005 | 01:28 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Mine has melted, cracked, crumbled, and vanished over time. I need a new one. Anyone know where I can locate one. it is a funny looking connector. Similar to the knock sensor connector. Thanks
Old Jun 29, 2005 | 06:48 AM
kevinc's Avatar
Car: 1982 Z28
I got one at PepBoys in the electrical thingies aisle. Whole rack of individual connectors on display, just dug around until I found that exact one.
Apart from that, a trip to the junkyard should do the trick...same connector is used on knock sensor in most GM applications.
Old Jun 29, 2005 | 06:50 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Could try gmpartsdirect.com they might have something. Besides that I would try the above suggestions
Old Jun 29, 2005 | 10:02 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yep, the knock sensor connector and the fan switch connector are the same kind, so they will interchange. Here's some places that sell them:
http://www.turbocity.com/product_inf...products_id=88
http://www.rosesandwrenches.com/conn...tors&UID=10037
http://www.madvet.com/shop?frame=1.138.944
Old Jun 29, 2005 | 08:50 PM
norcalz28's Avatar
Damn, shipping on a 5.95 part is almost 7 bucks. Screw that. I will see what I can turn up at the junkyard! Thanks fellas
Will
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 16, 2015 12:21 PM
