Service Engine Soon Indacator is On!!!
Old Sep 13, 2001 | 07:44 PM
89Firebird Formula350's Avatar
I have an 89 Firebird Formula and the service engine soon indicator came on just recently. What usually causes this to come on? Could it be anything major? Thanks a lot!
Old Sep 13, 2001 | 07:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get the codes an post them, someone should be able to help.
ICON Motorsports
Old Sep 13, 2001 | 08:09 PM
Vader's Avatar
...or load this file and get the information you need:
GM Error Codes.pdf
Later,
Vader
Justice and Freedom will Prevail
Old Sep 14, 2001 | 02:58 PM
I fixed the problem. I disconnected the battery for a couple minutes, and the lights went off, so thats good!
Thanks for your help anyway!
Old Sep 14, 2001 | 03:07 PM
Pino91Formula's Avatar
you probably didnt fix the problem you just cleared the stored codes once the car does what ever is not working it will trigger the code
Old Sep 15, 2001 | 12:32 PM
z28camaro396's Avatar
When the SES light appears again, check the codes using a jumper of some kind (hairpin's, wires). You can read how to do it in the FAQ section of the thirdgen.org home page at the bottom. If u need more help let me know.
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), kenwood c.d. player.
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
