car bogs when tryin to rev.
Old Sep 15, 2001 | 11:15 PM
1982chevycamaroz28's Avatar
when i go to give my car a rev like even alittle rev it bogs down and then back to idle, and if ur like goin to drive it once and a while it will back fire threw the carb but doesnt really do that im thinkin givin it a really good carb cleanin and when i get the exuast on maybe it will stop that. please respond thanx
mods to car
new ignition system, edelbrock intake,600 cfm q-jet,th-350 tranny, used black interior, grant stering wheel, accel plugs and wires, hookercat back, b&m shifter, emmission delete package, computer delet package and soon ac delete and in future-- hooker sump comp headers, posi rear, drag slicks and all new rims probably weld rims, line lock, 8 point roll cage, strut tower brace, drag shocks, sfc, new edelbroc 600 carb, nitrous and a weiand supercharger or a 350 or 400 block
Old Sep 15, 2001 | 11:40 PM
blitzkrieg442's Avatar
ok , hmmmmm lets see, i would say its your timing or a broken rocker, is it up to power, ae your lifters ok? if its popin you timing is messed up or you exhaust valve is not openin on one of your cylinders, i had a car that ran fine at idle, but when i steped on the gas, it poped through the carb, replaces a 2 dollar rocker arm and girdle, and i was set, i payed 150 for that car just because of that, when adjusting your timing, if thats what it is, be careful no to tightin down your distributor to much, you will strip it from the intake, and then u will be buying a new intake let me know how it turns out or what else )info ) u need
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
killer777
Aug 8, 2015 02:47 PM
