305 Head Availability
So, folks, aside from Vortech, L98 vette, and World Torquer S/R 305's, what heads are available or could be made to work with 305's. I have a pretty competent LB9 305, and there's no need to replace it with a 350. I would prefer to hear about aluminum heads.. and bumping up the compression would be cool too.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Jon
89 GTA
Airfoil
KN Airfilter
SLP 1 3/4 headers
No Smog/AIR system
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i am going to put on a set of aluminum L98 heads(vette) on my 86 LB9 TPI. the heads are gonna be gasket matched and ported and polished, with manley swirl polihed 1.94/1.50 valves with bigger springs to handle a .423/.446 but at 1.6 rockers and its .451/.475 and hope not to hit piston.
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
ambainb
Apr 25, 2016 09:21 PM
