mechanical woes
Old Jul 1, 2005 | 04:32 PM
pbkidd's Avatar
Car: 84 z28 HO
Engine: L69 305 HO
mechanical woes
Over a year ago I installed an edelbrock performer RPM power package on my 84 camaro Z28 HO. I put in a cam, lifters, intake manifold, and 650 cfm carb. I also put on a set of non egr headers and rebuilt the distributor. I was initially getting about 23 mpg. Recently, after my car sat without being driven for a couple of weeks I am getting around 10 mpg, the car seems to be missing and surging, sometimes it dies when I turn the steering wheel hard, and is very boggy when I step on the accelerator.
I have installed new plugs and wires and have looked over the ignition system and it all seems to be in good condition. I have even adjusted the timing and it still runs ****ty. I now have to keep the timing advanced just to be able to drive it.
Any advise would be greatly appreciated! Thanks!
Old Jul 2, 2005 | 01:46 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Just curious, you rebuilt your stock distributor, and put in an edelbrock carb right? a non computer controlled carb?
And the distributor is stock, computer controlled right?
I feel bad for you, no one has responded to your post yet, you being a new member and all...
But if you answer yes to the first couple of questions, then your answer is brutally obvious....... (otherwise i'll bust out some concious thought for ya )
Old Jul 5, 2005 | 06:52 PM
pbkidd's Avatar
Car: 84 z28 HO
Engine: L69 305 HO
The distributor is non computer controlled. It used to run just fine. thanks
Old Jul 5, 2005 | 07:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
ah, ok. Just thought i'd make sure that was out of the way first.
what is your timing at now? advanced how much?
i'd guess a carb adjustment is needed... However i'm certainly not the one to ask about an edelbrock carb, I imagine someone with more knowledge can chime in then....
(did you check if all 8cyls are getting spark?)
Old Jul 5, 2005 | 07:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Pull the top cover off and clean the needles and seats and make sure the floats aren't sticking.
Old Jul 20, 2005 | 05:50 PM
pbkidd's Avatar
Car: 84 z28 HO
Engine: L69 305 HO
thanks for the replies! I'll try cleaning the needle and seats. Thanks again!
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
