Changing the Oil Pressure Sendign Unit?
Subscribe
Sep 8, 2001 | 11:57 AM
Is a special socket required? If so, where can I get it? Thanks guys.
Reply 0
Sep 8, 2001 | 12:20 PM
As far as I remeber all you need is a deep 3/4 socket, and an extension and it'll come right out.
Reply 0
Sep 8, 2001 | 12:42 PM
Scott,
There is a special socket made for many sensors - somewhat of a 16-point design with rounded corners. However, you can usually use a standard six-point or twelve-point socket of the appropriate size and get the job done.
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Reply 0
Sep 8, 2001 | 12:43 PM
you need a socket for an oil sender, it's sort of a double hex, but with unequall length flats. most parts store sell them as well as the major tool makers. i have been able to use a regular 1 1/16" socket for the senders in the past but the socket made for them is the best way to go.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Reply 0
Sep 9, 2001 | 03:43 AM
Thanks guys. If I cant get it with a regular socket, I'll invest in the right tool for the job.
[This message has been edited by Scott_92RS (edited September 09, 2001).]
Reply 0
Sep 15, 2001 | 09:39 PM
I just replaced mine. I spent $40.00 for that special socket, just to find out that I cant use it. There's not enough space between the car frame and the sending unit for the socket to even fit over the unit. Its like replacing a spark plug with headers on. I had to use an extended open wrench to slowly unscrew the unit, but finally replaced the damn thing.
Reply 0
Sep 16, 2001 | 10:09 AM
i just changed mine the other day and all i had to use was a pair of vice grips or pliers and it came right out
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Reply 0
Subscribe
