fuel pressure going nuts
Old Jul 2, 2005 | 03:56 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i checked my fuel pressure for the first time today, it was right about 40 initially, i messed around with it a bit, and set it to about 47 or 48. all you do for this is put the pressure tester in the port, and turn the key right? so anyhow i get it set and it holds steady after it goes to 48, doesnt drop or anything. then i start the car and it goes crazy, flips back and forth really fast almost from one extreme to the other. whats the deal? i thought it was supposed to stay steady with the engine running?
Old Jul 2, 2005 | 09:24 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Re: fuel pressure going nuts
It IS supposed to stay steady... Actually when you SET the fuel pressure, youre generally supposed to set it with the engine running, and the vacuum line to the regulator disconnected and plugged, that way the pressure reading doesnt fluctuate. This is basically giving you your WOT fuel pressure reading and you adjust based on that.
I don't know why yours is bouncing like that....I've never heard of that before.
Old Jul 3, 2005 | 06:55 AM
1meanGTA's Avatar
i think i have a minor vacuum leak, doesnt want to idle low, i keep it set at about 800 and it only idles steady about half the time, rest of the time it jumps from 600-1000 and will die sometimes if im sitting stopped in gear with the brake on. it will idle steady if i set it to 9 or 1k but i like the lower exhaust tone lol. if i spray carb cleaner around the intake manifold area it will sputter and almost die. could a vacuum leak cause that the pressure to jump like that?
Old Jul 3, 2005 | 06:56 AM
1meanGTA's Avatar
do you mean plugging the vacuum line itself, or on the regulator where it plugs into?
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
