Stock exhaust mainafolds, and headers
Old Sep 16, 2001 | 01:17 PM
un4givin89's Avatar
I was trying to change my spark plugs, man what a job that is. And i was wondering if I get headers do they bolt on or do they need to be welded?? Cuase my current stock things on the engine look like they are bolted on. And i saw a set of Elderbroc headers that say they just bolt on. Plus is it true headers make getting to plugs easier?
un4givin89
1989 Camaro Ralley Sport, 305 TBI 5 Liter v8
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Interior swapped for two tone colors
Lowering Springs
Sound System
www.mikekey.net
Old Sep 16, 2001 | 01:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I got the Edelbrock TES headers and they can be bolted on to your stock exhuast at least they could for me. As far as getting to your spark plugs. It won't be easier, you'll have to get under the car for the back 2 plugs on the passenger side.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 16, 2001 | 09:16 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I think it's easier to change plugs with my TES, all from the top side. I pull the battery + terminal and use an 5/8" open-end wrench to get at #6&8 plugs.
If you get TES, get em fully JET HOT coated in/out. A set of Stage 8 SS header bolts will assure no problems later too.
1986 IROCZ-28 Site
Best Times:
60'=1.92sec, 1/4mi=14.42sec @93.99mph in 65deg temp
Old Sep 16, 2001 | 09:21 PM
reborn's Avatar
When doing a header swap does anything else gotta be removed to get the things in and out?
FOR SALE -84 Z28 HO
Asking $1700. Its got AC, White Ex, Tan int, all engine HO and emmisions equipment intact. More info email me at gmail@outgun.com
Yea ill get pics up soon.
Old Sep 16, 2001 | 09:29 PM
rezinn's Avatar
I've heard of moving the steering shaft or raising the motor to make room, but when I installed my headers, I also changed my heads, so I didn't need to move anything.
Old Sep 16, 2001 | 09:44 PM
Car: 99 Formula
Axle/Gears: 342
I didn't have to remove my steering column, driver side was easy, had some trouble on passenger side, remove smog parts, and AC was already out. The most time consuming part was getting the manifolds off and removing smog equipment.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Old Sep 16, 2001 | 11:40 PM
un4givin89's Avatar
Sounds rather interesting. Perhapps I'll have someone install them for me, has anyone paid to get it done and how much did that run you. I dont' know if I am that experinced at installing something like this.
un4givin89
305 TBI
ElderBrock Open Element
1 1/2 lowering springs
Project List:
Flowmaster Exhaust
New holley Fuel pump
Elderbrock Headers
Battery to Trunk
New Valve Covers
Windows tinted
Sound System
www.mikekey.net
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mustangman65_79
Aug 7, 2015 09:55 PM
