Pickup Coil
Old Sep 17, 2001 | 05:33 PM
ChrisH's Avatar
Pickup Coil
Im replacing my pickup coil and im having a hard time removing it from the distributor. I have the distributor pulled out of the car and I popped the pin to remove the gear. When I try to slide the rod in the middle of the distributor out, it get's stuck at about 1 1/2 to 2 inches from the bottom. I've also noticed the pickup coil is set in place by a pin and it doesn't budge at all. What's the secret to removing the coil? Since i've never replaced one before Im not about to go pounding away until im sure what to pound at.
Old Sep 17, 2001 | 05:40 PM
88TAJeff's Avatar
Car: 88 T/A
Chris, don't pound away at anything! spray some liquid wrench in there or something. The same thing happened to me, and this worked, it just takes some patience. The dist. shaft tends to get rusty in there after some time.
The pickup coil is held in there by a small clip on top of it. The new coil usually comes W/ a new clip, since it may get destoyed taking it out.
88 Trans Am 305 Auto Red/Silver, MSD coil,wires, ported plenum, gutted airbox, TB bypass, comp cams 08-408-8, everything else stock
Old Sep 17, 2001 | 06:06 PM
Jester's Avatar
What he said...don't start pounding. Spray a crap load of WD-40 or something similar..let it soak in..and slowly work it out twisting it back and forth.
Old Sep 17, 2001 | 06:28 PM
ChrisH's Avatar
WD40 is a friggen miracle spray!!!
After putting away my sledge hammer and taking your advice it slowly worked it way out. I just have to remove the pin and im good to go.
Thanks for giving me some patients...
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
