Are there any aftermarket intake manifolds other than S Ram/Mini ram?
From: Newark,NJ The state where racing on I 78 rules.
Whats up guys & gals?
Do anyone know of a alternative to the tuned port manifolds other than those two. It needs to be able to pull up to 6500 rpm & have the injector holes, fuel rail, etc. already made up for it. My motor is a 383 roller cammed engine. In the future I want to install either AFR 195s or GM fast burns. Anyone ever try the fast burns & what type of performance will I gain? GM says up to 500 without porting is that true?
THanx
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
THanx
njdaewoo
3inch
njdaewoo@excite.com
383sb engine
smog pump by-pass
GM Performance Parts makes ram jet fuel injection. You may want to see if you can just get a manifold(you should be able to). The fast burns I know can make up to 430 hp with the right combos, though you can probably get 500, but I don't know if it could get to 500 without porting and polishing.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
ambainb
Apr 25, 2016 09:21 PM
