oil sending unit
Old Sep 17, 2001 | 10:10 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
oil sending unit
i was looking at my oil gauge today and noticed it was sitting low and every time i would go around a curve the gauge would go all the way down and then when i straigtened the car back up the gauge would go back up to about 15-20 psi while i was sitting at about 1500 rpms i just changed the sending unit and its still doing it what else should i check
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Sep 17, 2001 | 10:44 PM
rezinn's Avatar
Your oil pressure should go down when you turn, since your rpms go down(hopefully) because you are slowing.
Old Sep 17, 2001 | 11:02 PM
maksik7's Avatar
While 15-20 psi at idle isnt great, its acceptable and shouldn't cause engine damage due to poor lubrication. But it defnetely should not drop to 0 around turns. Mybe you have too little oil left, do an oil change (might as well) and see what happens.
Hope that helped -Max
Old Sep 18, 2001 | 04:40 PM
89Irocz23's Avatar
my car at idle is like 30 psi, (idle at 600) but when I hit the gas it goes to 60 so I guess im good
Old Sep 18, 2001 | 05:08 PM
Enkil's Avatar
Oil pressure should never go all the way down, don't think I need to explain why. Since you've already changed the oil sender, buy/borrow/steal a mechanical gauge and see if that's what you're actually getting. Also check your oil level, but I'm betting you've already done that.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Sep 18, 2001 | 09:19 PM
i just changed my oil so i know its not that i plan on getting a gauge and see exactly how much psi im running (where do i hook it up at?)
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
