Griffin radiator users>>>
Old Sep 17, 2001 | 08:29 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I have a Griffin 2 row alum. radiator, the stock replacement w/ trans cooler. It's almost 2x as thick as the stock radiator, what'd you guys do to keep it in place? Just looking for some good ideas.
89 IROC-To see mods go to: http://www.geocities.com/buckeyeroc
Old Sep 17, 2001 | 09:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have the 3 row and I used my stock radiator cover to hold it in place, it doesn't fit perfect but it holds it in place.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 18, 2001 | 08:56 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
mine is a becool. It has the little aluminum pieces that fit into the end tank slots that were in the old radiator hold down. I did have to modify it a bit to clear the spal fans.
Old Sep 19, 2001 | 04:59 PM
BuckeyeROC's Avatar
ttt
Old Sep 19, 2001 | 07:32 PM
ede's Avatar
ede
i changed to a smaller size on my car, had to change the mounting as well. all i did was use some flat steel bent at 90* and used selftapping sheet metal screws to hold the straps on and against the radiator, i used weather stripping on the straps to to act as a cousion between the radiator and the straps.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
1MeanZ
Dec 18, 2015 05:39 AM
camaro1185
Oct 26, 2015 06:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
