inline fuel pump?
Old Jul 10, 2005 | 01:37 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
inline fuel pump?
is puttin an inline fuel pump bad top on top of a stock working one?
if so can i can the power to the stock one and use the inline?
can u even use an inline with a EFI setup?
thanks.
Old Jul 10, 2005 | 09:57 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
You can run an inline pump on top of your stocker, but you have to keep putting power to both pumps, the inline will not pull fuel through a non operating pump. With that said, if your trying to make up for a dieing pump, then your really need to replace it anyway, and Walbro pumps are cheap when compared to in-line pumps. @ 110$ you can alost take the money that you save by going with this pump and pay some one to put it in.
Old Jul 10, 2005 | 11:19 AM
Borsty's Avatar
Car: 89 Trans am
stock one is fine, just need more flow for about 150 more hp over a stock one
will that work?
Old Jul 10, 2005 | 01:03 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Moved
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
