alu heads screw in studs torque setting
Old Jul 10, 2005 | 10:25 PM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
hi
113 heads, stock screw in studs, which is correct value to torque it? 35 or 55 lb-ft or maybe another?
thanks in advance
Old Jul 11, 2005 | 03:45 PM
sixpackmtrspts's Avatar
your talking about the rocker studs correct? not sure on stock heads but on the set f dart pro 1 i used on my last engine build the spec was 45 ftlbs.
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Aug 25, 2015 12:54 AM
IrocZ'85
Aug 17, 2015 06:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
