shooting oil!!!
Old Jul 11, 2005 | 03:45 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
shooting oil!!!
once in awhile when i start my car and rev it a little it shoots what looks to be a mix of oil and gas(to liquidy for just oil) out of my tail pipes!! would this meen i will have to rebuild it? or just replace the valve seals?
Old Jul 11, 2005 | 03:54 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Are you sure that it is gas in the oil? have you pulled the dipstick to see what the oil looks like? Make sure it is gas and not water or radiator fluid
Old Jul 11, 2005 | 05:01 PM
i think it is, the dipstick is a little darker than usual.
Old Jul 11, 2005 | 06:09 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
run you finger down the dipstick and see if it feels milky. Does the car run any differently than usual
Old Jul 11, 2005 | 07:33 PM
it is not milky and it runs the same as before. could it be that i just need new piston rings? if so, how hard is that to do?
Old Jul 11, 2005 | 11:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Does it have an odor? How does it feel?
Old Jul 12, 2005 | 12:16 AM
EvilCartman's Avatar
Car: '82 Z28
Sounds like condensation in the exhaust picking up the crap in there shooting out black water spots.
Old Jul 12, 2005 | 12:23 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yeah, oil and fuel making it to the tailpipes is probably rare if the car runs good.
Old Jul 12, 2005 | 02:52 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Yup, your car could also be running rich
Old Jul 12, 2005 | 03:08 AM
sixpackmtrspts's Avatar
sounds to me like condensation that builds up as anormal part of combustion, pretty normal for cars with cats on them. once the cats get to normal temp the fluid should go away as the exhaust is over 600 degrees.
Old Jul 12, 2005 | 08:52 AM
so do u guys think that my car is fine? and if it is running rich, how do i tell and how do i fix it?
Old Jul 12, 2005 | 09:35 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
When your driving do you smell a real rich smell form the exhaust? you could also buy a gauge to hook up to your O2 sensor
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
CatmanFS
Sep 19, 2015 09:00 AM
