stock z28 pistons?
Old Jul 11, 2005 | 04:12 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
stock z28 pistons?
I have a 305 from an 85 Z28 4bbl, i'm researched on google and found that they had 9.5:1 compression, but what kind of piston's did the motor come with? Where they flat, dished or domed?
My set of now are flat top pistons with 2 valve reliefes (they have 0.030 stamped on them), but I cant remember if I had the shop put in a new set or just use the ones that were in there.
Old Jul 16, 2005 | 02:16 PM
Vader's Avatar
If the pistons now have "0.030" stamped on them, they are likely not the originals.
The original pistons should have been flat tops with four valve reliefs.
Old Jul 16, 2005 | 03:26 PM
Car: 88 Camaro
Engine: 310 LG4
Ok, so with only a 2 valve, would that effect compression at all? I'd imagine if so, not by a noticable amount.
Old Jul 16, 2005 | 09:39 PM
Damon's Avatar
No, probably not by much. Stock 4 valve relief flattops usually end up with about -6cc worth of total "dish" volume. 2 valve relief (aftermarket) pistons would be not quite half that. About -4cc being typical. A tenth or two of a point difference in compression maybe.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
