Help, oil pump or gage cause of low oil pressure ?
Old Sep 20, 2001 | 07:42 PM
dnovotny's Avatar
As always, I'm loathe to bring my car in to the mechanic (do most work myself). So, the gage indicates 0 oil pressure sometimes (car used to be solid 30 or 60 psi). What are the best and easiest ways to figure out if its a sensor/gage problem vs. oil pump problem.
Thanks, Dave '91 T/A, '91 GTA, '01 T/A WS6
Old Sep 20, 2001 | 08:13 PM
BrianB's Avatar
I had the same problem, and all it was, was the oil sender that is bolted on the back of the manifold. It looks like a small fuel filter with an electrical connector. Or it could be the one that is right above your oil filter. I changed both of mine, they are inexpensive. Hopefully that is all that is wrong.
Old Sep 20, 2001 | 08:18 PM
j166a99's Avatar
YUP, i'll bet $$money$$ that its your oil sending unit.
mine was out for a while and would constantly drop to '0' when i hit the brakes to a complete stop. replaced it, and now i'm gold.
Old Sep 20, 2001 | 08:48 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
hey brian is that an oil sending unit on the bac kof the manifold or it it the oxygen sensor
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Sep 21, 2001 | 03:06 AM
Omar's Avatar
Easiest way is to verify the pressure with a mechanical oil pressure gauge. Your sending unit should be above your oil filter.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Sep 21, 2001 | 10:25 AM
BrianB's Avatar
The oil sending unit that is on the rear manifold,or some people call it an INTAKE. It is right next to the distributor on the drivers side. Your oxygen sensor is screwed into your drivers side exhaust manifold.
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
Old Sep 21, 2001 | 11:24 AM
dnovotny's Avatar
Thanks guys, I'll replace the oil sending unit over the weekend. My symptoms are identical to j166a99.
Thanks, Dave
Old Sep 21, 2001 | 11:40 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Actually, the oil pressure sender is in the block, not the intake manifold.
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
