Broken hood release, urgent!
Old Jul 12, 2005 | 01:04 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
So my hood release broke today, the cable flat out snapped.
How can I get into my car's engine bay? It doesnt look like i can even see the latch from underneath, anyone have any ideas? The car is stuck at work because it needed water.... and now i'm screwed.
Old Jul 12, 2005 | 01:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Do you have any idea where the cable snapped?
Old Jul 12, 2005 | 03:11 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Right by the latch
Old Jul 12, 2005 | 05:05 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
If you can see the cable then grab it with a pair of vice grips. Otherwise cut away the outer shell of the cable a bit till you can see the cable then grab it with a vice grips. Lucky it's where you can still reach it.
Old Jul 12, 2005 | 06:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Right by the latch, as in under the hood eh?
So I don't think you can reach it then can you?
Sorry, I'm no help here, I guess try reaching up under the car with a flatblade screwdriver and see if you can jimmy it open. Best of luck.
Old Jul 13, 2005 | 01:33 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Incase this happens to anyone else... there is a little access panel snapped into the splash gaurd, remove that, and then take a scredriver and slide it up to the latch and use a level action to pop it.
The cable came off the clip that holds it. pretty crappy, i put a tack weld on it so i didnt have to go through that again.
Old Jul 13, 2005 | 05:26 PM
sixpackmtrspts's Avatar
i just reached thru the opening next to the license plate mount in the nose of my 82 and moved the lever with my fingers
Hotrodboba400
Dec 10, 2019 07:07 PM
skeltor
Feb 2, 2016 10:37 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
