stock carb'd electric fuel pump
Old Jul 12, 2005 | 10:48 PM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
I was surfing Hotrod's site (surprizingly big) and came accross the My Generation Camaro buildup. I started reading and on part 2 they state:
This ’87 was the last year for carburetors on third-generation Camaros. It employs a small electric in-tank pump that pushes fuel up to an engine-driven mechanical pump. Even this combination of electro-mechanical pumping action is insufficient, so that’s where we went next. We bolted on a stronger Holley mechanical pump to ensure the feedback Q-jet carb had plenty of fuel.
Is this true? For Firebirds as well? 82 Firebirds? Because I have a lot of shop manuals and illustrations and I do not remember seeing this anywhere (for carb'd cars at least) . Should/can I change this out?
Old Jul 12, 2005 | 10:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In the early years the carbed cars only had the mechanical pump. I think only 1987 had both the electric pump and the mechanical pump from the factory, although an electric pump was sometimes added by the dealer as part of a kit to fix vapour lock problems.
Old Jul 13, 2005 | 10:57 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The low pressure pusher pump in the tank on carb'ed cars was to help aleveate the hot soak/vapor lock problem that the L69 cars had. 83-early 84 with the dealer installed TSB fix and late 84-86 L69 5.0L HO and '87 LG4 5.0L will have factory installed helper pump. The '87 LG4 is basically an L69 minus the better camshaft and high flow exhaust.
Old Jul 13, 2005 | 11:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
...and air cleaner. And flattop pistons (slight dish in '87).
But, unless added, your '82 won't have the pusher in-tank electric pump.
Old Jul 13, 2005 | 01:58 PM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
thanks greatly for the replys
Old Jul 13, 2005 | 11:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am not sure if your 82 will have one, but my 1983 G20 had one. I used the wiring to run the TPI pump in a TBI tank.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
