Serpentine belt routing
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
anyone have a diagram of the serpentine belt routing for a 88 IROC w/350 and A/C??? please and thank you
1988 IROC-Z L98
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, AFPR, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over.
Nitrous System:
NOS Plate Kit, 100hp shot.
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter
ET: 13.833@99.30 N/A
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
1988 IROC-Z L98
Engine Mods:
Nitrous System:
Suspension Mods:
Trans Mods:
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega ShifterET: 13.833@99.30 N/A
www.mfba.org
I could describe it to you... If you start at the crank wrap the belt around ccw to the left side of the water pump so the ridges are up, then over the water pump to the bottom of the power stearing pump, up and around the alt. under the tensioner, over the AC and around the smog pump, back to the crank. Hope this helps.
Jim
Jim
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by camaroguy99:
Jim</font>
Jim</font>
This link might help, but its missing the smog pump and the power steering pump: https://www.thirdgen.org/newdesign/t...rpentine.shtml
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Car: 84 Camaro Z28
Engine: 5.3
Transmission: Tremic 6 Speed
Axle/Gears: 3:43 posi
Re: Serpentine belt routing
I have to install the serpntine belt drive on to our Chump Camaro and the question is, Is there a way to remove the AC and Smog pump and still use the set up? Our Race car doesn't need either unit.
Thanks,
Russ
Thanks,
Russ
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I found two different routing diagrams on this site ,all you have to do is scroll down this page. It shows 1988 and 89 to 92 .
= http://sethirdgen.org/serpentine.htm
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
cagedruss: you have to use a delete pulley on the A/C, then you can bypass the smog pump acording to the link above.
