help W/ Build-up ideas.
Old Jul 15, 2005 | 11:15 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
Alright, I bought a 350 4 bolt main on wednesday, and need to rebuild it. I am trying to get ideas with what I can build here. This was my initial thought:
355 cu inch
bore .030 over
forged pistons
stock crank
vortec heads
vortec intake
dont know which carb
comp XE 274
long tubes
Anyway, I want to make close to 300 rwhp, through a 700r4. How does this plan sound? Any suggestions to change the plans? How about add where I am missing? I do not want to spend over 2 grand on this motor, but obviously willing to go over a bit, since it will take awhile anyway. So what is your budget idea for a nice 355?
Old Jul 16, 2005 | 01:58 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
I think that engine will rock pretty good. When you go to that kind of cam though you'll need a torque converter and also you'll have to watch your springs on those heads. I was going to get that same cam but the lift came too close to my max on my heads. I would suggest changing the springs out to the comp cams recommended ones. Also make sure you get roller rockers and change out the oil pump while you're under there. I would suggest the edelbrock rpm air gap intake if you want some rpms. As for a carb, get a holley 650 dp should make you happy. Good luck with the build up.
Old Jul 16, 2005 | 01:36 PM
sixpackmtrspts's Avatar
i too say go with the air gap manifold, a 650 holley or barry grant demon carb would be fine.
Old Jul 16, 2005 | 07:01 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
Sweet, just getting ideas for now. I will probably go with that air gap manifold. Think a 2400 stall would work good with that XE274 cam? Also, what gears, 3.73? What could I expect with a drivetrain like that? My goal is roughly mid 13s or better.
Old Jul 17, 2005 | 02:00 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
anymore input?
Old Jul 17, 2005 | 04:36 PM
3.73 with the 700r4 should be fine, you could go with a 4.11 also depending on tire size. 13's should be easy with this combo if not faster depedning on suspension setup.
Old Jul 17, 2005 | 09:23 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
since this is not my daily driver, I have nothing but time to do this, so I plan on doing a nice suspension so I can hook up at the track. Also plan on a better rear end, so i can run drag radials.
Mark_ZZ3
May 24, 2018 01:02 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
83ho87gn
Sep 26, 2015 08:49 PM
83ho87gn
Sep 24, 2015 08:58 AM
GTAman
Sep 21, 2015 09:57 AM
