new steering column?
Old Jul 17, 2005 | 04:08 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
Transmission: 700r4 w/ b&m shift kit
i bought an 86 iroc but the keys were lost. the steering column is perfectly fine except it is missing the place for the keys, its just a hole. right now its got some ghetto set up for starting. how much would it cost to fix the problem or what could i do to fix the problem. replacing the steering column is an option but an expensive one. is there a way to cheaply fix this?
Old Jul 17, 2005 | 10:12 AM
Vader's Avatar
Replace the ignition lock cylinder. Your description seems to indicate that your's is missing. You can get a new one with two keys for about twenty bucks.
Old Jul 17, 2005 | 10:18 AM
Vader's Avatar
If you use the board feature, you can find lots of threads with directions on how to install it, like this one:
https://www.thirdgen.org/techbb2/sho...hreadid=113811
Old Jul 17, 2005 | 06:47 PM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
i also didn't consider the locks on the t top. is there a way to replace the door locks and t top locks to match those of the new ignition lock cylinder?
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
