Rear end swap
Rear end swap
I own an 84 TA 4bbl HO. Unfortunately, I have a regular differential, 3.42s. I want to switch to a limited slip. I believe that a 3.42 limited slip rear end is available, and I was wondering if it would be a direct bold on, or would mods need to be done? Also, how much would the new rear end be, and where could I get one (outside the dealer if possible) Thanks for any replies.
Car: 2002 SOM z28
Unless you are interested in getting disk brakes or something along with the new rear... just get new 28 spline axles and a posi and swap that! It will be cheaper in the end.
Look at Moser for the axles and SLP for the posi.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
