Jul 17, 2005 | 03:05 PM
I'm having trouble diagnosing a problem with my rad fans. I got a 89 GTA 350tpi, the fans stopped workin so i changed the water temp sensor, rad fan switch, and the fan relay, still nothing...I checked the error codes and nothing shows up. Any ideas?
Reply 0
Jul 17, 2005 | 04:12 PM
Have you tested the fan wiring for continuity with a volt meter?
Normally i would disconnect the fan plug and test them, i take it you checked the fuses?
All it takes is a broken wire, if there are 2 fans i can't see the motors both seizing up.
Reply 0
Subscribe
