Q: Eliminating Redundant Temp Sensor
Old Sep 25, 2001 | 08:58 AM
Mrfixit's Avatar
I'm not quite sure if this belongs in this topic or TPI...
I'm installing an 89 350 TPI motor into my 68 Camaro and am planning on using an electric fan. I want to use only one temperature sensor since I'm using only one electric fan. I assume I need to use the sensor that's in the front of the motor installed in the lower intake and not the one in the right side head... correct?
Thanks,
Roy
Old Sep 25, 2001 | 10:14 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, that is the correct sensor (front of intake) for the ECM, which then will send a signal to the primary fan relay.
But, I'd still wire in the one in the head too, if the ECM fails, or the CTS fails to read correctly, it may not tun on the fan.
Using a 2ndry fanswitch is a good safeguard to have. Even single fan factory setup use the fanswitch.
Old Sep 25, 2001 | 12:46 PM
Mrfixit's Avatar
Thanks Mike. It sure is a comfort knowing that there are knowligable people on this board that can provide occational sanity checks.
Roy
Old Sep 25, 2001 | 01:59 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
Even single fan factory setup use the fanswitch.</font>
The 85-86 single fan setups use the CTS only.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BLK87Z
Sep 18, 2015 11:29 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
