Ignition Cylinder Removal
Old Jul 19, 2005 | 06:31 PM
boneyard buick's Avatar
Car: 1986 buick regal
Engine: 350 tpi
Transmission: th350, b&m shift kit
hey guys got a 1988 camaro with no keys so i got a new igniton cylinder, and i have no clue how to take the old one out and RE-INSTALL the new one, any help would be aprreciated thanks alot
Old Jul 19, 2005 | 07:05 PM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
Funny this came up... i just had to replace mine yesterday.
First.. i'm assuming you have a factory steering wheel. You'll need a steering wheel puller, and a lock plate remover.
Take off the horn cover. Take off the steering wheel nut. Use the steering wheel puller to pull the steering wheel. Use lock plate remover to press the locking plate down, then remove the retaining ring (looks like a wire around the shaft.. should just need a screw driver or a pick). After you pull that you just need to loosen the lock plate remover and pull the lock plate off. Under that you should have a electrical contact ring for the horn or what not, and under that the blinker assembly. Loosen all the screws and disconnect the arm from the assembly. Gently pull the assembly out (be careful, all the wires need to stay connected.. just pull it out enough so that you can see the screws behind it.) On the right, you should see a small torx nut which is black in color, by itself, under th lock cylinder. Loosen this screw, and pull it out. You should be able to pull the old lock out and put in the new one.
Now, if you have an 89 or later with VATS, there will be wires leading down the steering coloumn. The new lock should have these same wires and just run to the same connector and click in. You'll need to find out what blank you had, and purchase a new key and get it cut to the same mechanical cut as the new keys that came with the cylinder.
No VATS? Well, then your done with no wires, and you just put the new one in and put all the stuff back together the way you found it.
Good luck.
Old Jul 19, 2005 | 07:07 PM
Engine: 350 tpi
thanks buddy, its really good to have a forum on the net where everyone can get toether and help out everyone who needs it.
makes life alot easier
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
