my cars compression
Old Jul 20, 2005 | 01:25 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my cars compression
Im using my old 305 heads on my 350 block, which makes around 9.75 compression with the rest of my motor specs. what grade gas do you guys think i should be running?? do you think i could get away with 89 octane? or no. i've been running premium, but its getting a little pricey so i wanted to know if i could bring the octane down safely. i know im probably going to have to change my timing as well.
Old Jul 22, 2005 | 06:55 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Do a internet search and then a little research on "water injection"
With a simple water injection system you very likely can run full timing without knock using 87 octane gas.
Water injection typically improves the apparent octane performance of a certain grade of gas by about 3-4 octanes.
Old Jul 22, 2005 | 10:30 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Wow, that is very interesting. I haven't heard anything about that. With my vortecs, I'm expecting about the same(9.8). I wonder if anyone on these boards are using that?
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
