Knock at idle
Old Jul 21, 2005 | 01:19 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Knock at idle
Alright, My 2.8l V6 engine will kock at idle this knock sounds like a rock in a can shakeing, It only does this when the car is cold and it will stop making the knock at around 200 degrees. The idle is set at the first line after the 500 rpm mark. (around 650ish) What would be the cause of this knock? Now i do know that if i advance the idle to around 1000 rpm, the knock will stop. This really gets me fustrated.
Old Jul 21, 2005 | 03:05 PM
merc3065's Avatar
Car: 87 GTA
I was told that it is not uncommon for engines to knock when they are cold due to oil draining down into the pan and not lubricating everything 100% on start up. Apparantly most of the commercials are correct saying that start up is the hardest time for a car's engine due to the lack of oil on the moving parts up top.
If after it warms up there isn't an issue with it knocking, im not sure if you should be too concerned.
If you can, hook it up to an ALDL computer and record your cold start up and see what the knock counter reads at. If the knock counter isn't reporting very many knocks on start up then it may be something other than pistons knocking.
Old Jul 21, 2005 | 03:12 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Ive heard the same thing, however if the idel is up at around 1k parked (yes i know its 2 high) the car will not knock.
Stroopwafel
Sep 11, 2015 06:38 AM
FormulasOnly
Sep 10, 2015 09:07 PM
IROCtometal
Sep 9, 2015 10:01 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
