Anyone that has done a "smog pump delete"
Old Sep 26, 2001 | 08:19 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm working on an 89 TPI and I need to know what idler pulley/bracket and belt I need to retain the A/C and delete the smog pump.
Thanks in advance.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 26, 2001 | 08:31 PM
crucial's Avatar
There is a tech article on this!
Old Sep 26, 2001 | 10:12 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn, think I gotta find what shop Engineboy works at the next time I *need* to pass a smog test
Old Sep 26, 2001 | 10:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You dont need a pulley all you need is a differant belt but I forget the size
Old Sep 26, 2001 | 11:04 PM
SHE DVL's Avatar
Get a Gates K060975. Or a belt that's 97.5" long. I think the tech article says to use one that's 80", but that was too long for my car. Actually I've done this to both my thirdgens, and the 97.5" fit fine on both. If you want you can plug the manifolds with 1/4" brass plugs to clean up the engine bay a little more.
Michelle
92 Formula 350
91 Z28
Old Sep 26, 2001 | 11:22 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Thanks all, I read the tech article and found what I needed. (I always forget to look there )
Michelle: Ditched the stock ex. for block hugger headers...its in a 57 chevy
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
italiano67
Dec 11, 2016 09:21 AM
Abubaca
FAQ Board
166
Nov 6, 2013 01:01 AM
Anniversary-Z-man
Aug 29, 2005 11:18 AM
Dan87IROC-Z
Feb 15, 2001 02:01 AM
