Can I make holes in my Intake Gaskets?
Old Sep 26, 2001 | 08:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I bought trick flow heads and they said go with the bigger intake gaskets. I went with them and they dont sell them with the heat cross over holes. Can I just cut my own out? BTW they dont make that big of intake gastet witht he crossover there already.
Old Sep 26, 2001 | 09:11 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No reason you cant. Just leave as much gasket material as possible around the intake runners. If you need to get fairly close to the runners spread a thin layer of silicone on the gaskets.
SSC
Old Sep 27, 2001 | 02:58 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
<font face="Verdana, Arial" size="2">Originally posted by Mkos1980:
I bought trick flow heads and they said go with the bigger intake gaskets. I went with them and they dont sell them with the heat cross over holes. Can I just cut my own out? BTW they dont make that big of intake gastet witht he crossover there already.</font>
I took a dab of grease and put around the hole, lined up the gasket, sharpened a piece of old 1/2 pipe and stamped the hole. It lined up perfect so I used the first gasket to line up the other side. With the TPI intake I didn't need two holes as it turned out but it didn't matter. This worked for me on my TFS 23 degree heads.
_ ___ _
SMasterson
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
