crankshaft pulley removal part II
Old Sep 26, 2001 | 03:22 PM
rag93vette's Avatar
now its all off and it wont go back on. the bolt for the balancer installation tool wont thread and neither will the crankshaft pulley bolt. it sure came out and now it wont go back on. now it looks like some threads stripped out of the crank a few pieces of metal came out of the hole. so much for an easy job. i just dont understand why it came out but wont go back in.
Old Sep 26, 2001 | 05:54 PM
camaroguy99's Avatar
You've got a big problem. First try tapping the hole to clean up the threads and try it again. If that doesn't work, I would try getting a slightly longer bolt in hopes that you may have just damaged the first couple threads. Thats what happened to me.
Old Sep 26, 2001 | 06:03 PM
ede's Avatar
ede
just a WAG but i'd say your puller messed up a few threads when you removed the dampner. try chaseing the threads with a tap 7/16-24 i ithnk.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 26, 2001 | 07:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Close, ede... it's 7/16"-20 (fine thread)
ICON Motorsports
Old Sep 26, 2001 | 07:12 PM
JETHROIROC's Avatar
Did you used one of those caps, like the one I have from Tavia, to protect the crank snout from puller damage? If not, I'd say ede's guess is right on. Try cleaning the threads as he suggested.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 27, 2001 | 03:56 PM
rag93vette's Avatar
it looks like i messed up the first few threads. tapped it out and all went back in fine. got it running again thanks for the help you will hear from me again i am sure.
Navy8125
Aug 22, 2015 07:13 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 12, 2015 11:33 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
