Head swap/ compression ratio ?'s
Old Jul 23, 2005 | 06:14 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I have a question.... about compression ratio. My engine that i have in the garage has about 8.5:1 compression with 70cc heads, what kind of compression should i be getting if i swap to 64cc heads.
Old Jul 23, 2005 | 08:42 PM
Damon's Avatar
Chevy didn't make many 70cc heads. If this is a 350ci engine with that rated compression ratio it's probably got 76cc heads on it.
Anyways, if you swap on some 64cc heads along with a typical Fel Pro .039" rebuilder head gasket you'll be at about 9.1:1. If you use a slightly thinner GMPP .028" head gasket you'll be at about 9.3:1
Old Jul 24, 2005 | 01:18 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Thanks for the help... im fixin' to go outside to put the exhaust back on my car because i took it off to fix my torque arm mount.. i'll get the casting numbers off my engine in my garage and double check, but thanks.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
86IROC112
Aug 21, 2015 07:20 PM
