Can't get gauge cluster out....help please
Car: 89 IROC-Z
Engine: 383
I'm trying to replace my speedo cable and I can't get the cluster out. I have all the bolts out but it won't pull out. It seems like it's caught on some clips or something that are under the speedo and tach. How do I release these? Is this even what's holding me up??
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
--RPM Racing--
Car: 4
Engine: 6
Transmission: 5
There are 2 nuts, 10mm IIRC, at the 2 bottom corners of the cluster, down in cavities beside light bulbs. Then after you take those out, the speedo cable will keep it from coming out very far; disconnect it from the cruise regulator and push some of it into the dash, then you can reach behind the cluster and push in its little retainer clip.
ICON Motorsports
ICON Motorsports
