need some help, car barely made it home
Old Jul 24, 2005 | 12:38 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
So I'm driving home from work on friday and all of a sudden the engine starts acting up. I'd call it "choking" The car started jolting back and forth so I pulled over turned it off, Started it up again, let it idle for a few seconds and it died. Started it up again, and got it goin, altho it started getting very rouch and choking at about 3000 rpm. Got it home tho. Didn't touch it yesterday. Tried it this morning. ran fine for a while, then I hit the gas abit harder and it choked and got bad again. This time choking about 1500. I gotta leave for work right now so I can't go into much more detail at the moment. Any suggestions on what it might be? Thanks in advance.
Old Jul 24, 2005 | 12:50 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Had that happen once,turns out the fuel filter was clogged as ****!
Old Jul 24, 2005 | 10:32 PM
Car: 88 GTA
I thought a clogged filter would just generally give me overall lower performance. Worth checking out though.
Old Jul 24, 2005 | 10:35 PM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
low fuel press? how old is the pump? also could be water in the gas making run ****tyy
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
hokis
Aug 9, 2015 03:57 PM
