CCV Hose
Old Jul 25, 2005 | 08:14 PM
91Z28-350's Avatar
CCV Hose
I think this thing is about 1/2" ID. Does anyone know where I can get standard unmolded hose for this? The only hose I've found in 1/2" ID is heater hose, which probably won't work too well if/when blowbly occurs, for the same reason heater hose isn't used for the PCV valve. The internal of the hose is a bit oily after high load runs. I want to run it to a catch can to see how much oil is coming out. The only hose that I think will hold up, from what I've found at Pep Boy's, is 3/8" fuel line hose, which is 1/8" too small.
I know I can get the molded hose through GM, but that doesn't help.
Thanks!
Old Jul 25, 2005 | 08:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You should be able to find 1/2" emissions hose somewhere.
Old Jul 26, 2005 | 12:17 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Hmm... CCV hose. That hose is a wacky shape going from the throttle body to the right-side valve cover; I'd want to use a molded hose to avoid kinks.
I believe the hose is 5/8" O.D., so 1/2" I.D. sounds correct. Have you tried NAPA? They carry Gates hoses and I know for a fact that Gates makes emission hose in that size.
HTH
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
