Piston install, have I gone retarted???
Old Jul 26, 2005 | 09:40 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I got my engine from the shop the other day and I'm putting it together. This is my 5th engine that I've built so I have a general idea what I'm doing, but its been about a year and a half since my last build. Problem is the pistons. I cannot for the life of me get them installed. I put the ring compressor on, tighten it down, make sure its flush against the deck, and then tap it in with a wooden dowel and rubber mallet. However, when it gets the to botton ring on the expander its just pops out between the compressor and the deck. I don't remember having problems like this with my other engines. Is there something I'm missing, forgetting?
Old Jul 26, 2005 | 09:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What kind of ring compressor are you using?
Old Jul 26, 2005 | 10:11 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
The old MAC
Old Jul 26, 2005 | 10:35 PM
Redbird87's Avatar
Engine: 355
Re: the old Mac
That's the same compressor I use. I hold the compressor with one hand to keep it tight against the block and tap the piston gently with a hammer handle or push with same hammer handle until bearing is seated on crank. I've found if I don't hold pressure on the compressor to keep it seated the oil scrapers escape!!! Hope this makes sense, Dave
Old Jul 27, 2005 | 01:08 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yeah, hold the compressor in one hand, and hit the piston with the hammer handle with the other hand.
Old Jul 27, 2005 | 05:01 AM
ede's Avatar
ede
spend a few bucks on a tapered compresser and you'll never use anything else and you won't have any more problems.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
