Buying open element air filter, what do I need?
Old Sep 30, 2001 | 05:38 PM
91RedFire's Avatar
What do I need for this conversion for a 14" element, which is the best, and where do I put my PCV valve after the new element is on? Anybody have any HP gains from this, and how long should it take? Thanks.
1991 Pontiac Firebird
51k Miles
T-Tops
Fire Engine Red
305 TBI
[This message has been edited by 91RedFire (edited September 30, 2001).]
Old Sep 30, 2001 | 07:05 PM
91RedFire's Avatar
Well I went out and bought a 14" Edelbrock Pro-Flo Chrome Open Air element. Now what?
How do I go about installing this?
51k Miles
T-Tops
Fire Engine Red
305 TBI
Old Sep 30, 2001 | 07:09 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
go to the TBI board....look under topic "TBI upgrades" and follow trigenRS link..it will show you everything you need to know.
92' Camaro RS/Black,T-tops/350 TBI Targetmaster Comp.engine/5 spd/march underdrive pulleys/hedman hedders/3" dynomax exaust/hyper tech stage 2 chip/3.42 gears/K&N air filter/MSD blaster GM coil.......currently setting in my garage impatiently waiting for installation....TPI !!!!!
[This message has been edited by david roush (edited September 30, 2001).]
Old Sep 30, 2001 | 07:10 PM
Enkil's Avatar
Well, the pcv valve isn't connected to the air filter at all. Installation is simple enough. Remove the old one. To do this, remove the breather element, held in place by a clip. Then remove the vacuum hose running to the thermac. (That round thing on the snorkel) Then, remove the sensor that's sticking into the air filter. It kinda wiggles out if I remember. The new element just plops down into place. The breather can just be placed aside, as can the sensor, although you'd get more use out of it if you put it into the new air filter. It's probably got holes in the base that can be tapped out for this purpose. The vacuum hose that used to run to the thermac needs to be capped off.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Sep 30, 2001 | 07:40 PM
91RedFire's Avatar
Thanks for the replies guys. The only thing that is getting me is the blue AC sensor, and some other wire goieng up to the old element holder. What should I do with these?
51k Miles
T-Tops
Fire Engine Red
305 TBI
Old Sep 30, 2001 | 09:04 PM
91RedFire's Avatar
Thanks for everyones help. I am finsihed and it sounds awesome! It also seems to pull harder too. Definately the best mod for my money so far. I just left the breather on the side of the air filter, just hanging there, so hopefully it should be ok. Again thanks!
51k Miles
T-Tops
Fire Engine Red
305 TBI
1992 Trans Am
May 10, 2023 07:19 PM
theurge
Aug 21, 2015 12:46 PM
wruiz
Aug 13, 2015 09:07 PM
Zachattack0925
Aug 12, 2015 09:52 PM
