LT1 parts on a 350 block?
Old Jul 27, 2005 | 12:14 PM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
Will parts from an LT1 work with just any 350 block? I was looking on ebay for an LT1 with a 6 speed and they are pretty cheap from what ive seen, but i was planning on building the motor for it but i dont see the point in putting it in then taking it out later to build the internals because i have a 4 bolt 350 sitting in my garage. So will the heads, cam, intake, etc. bolt onto this block?
Old Jul 27, 2005 | 04:02 PM
Axle/Gears: peg leg
Anyone even know anything about this?
Old Jul 29, 2005 | 02:17 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Will they bolt on? Yeah. Will they work when bolted on? No. Can they be made to work? Yes, read here. https://www.thirdgen.org/techbb2/sho...hreadid=178262
I got my heads/intake working on my 305, and then shortly after I spun a rod bearing since I was revving the stock bottom end too high. Now I'm about to swap the heads and intake over to a built 355. I hope to have it running in the next week or so.
Old Jul 31, 2005 | 05:58 PM
Axle/Gears: peg leg
What about tpi equpiment? would that stuff bolt onto a 327 also, i know the it will go onto the 350 easily i have other options also so any info is helpful, thanks you.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Jan 29, 2017 07:00 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
1nastygta
Aug 8, 2015 07:38 PM
