AC Compressor Erratic Engagement
Old Jul 27, 2005 | 03:47 PM
RallySportin''s Avatar
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Transmission: 700-R4
Well my AC has not been blowing out cold air, and my compressor is engaging and disengaging every few seconds. When the AC is switched to on, the compressor will turn on for around 5 seconds, then switch back off for a few seconds, then turns back on and continues to cycle. Pressure readings on low side port ae kind of hard to get due to the erratic engagement, but they are high. Pressure when compressor is off is around 120, then when it engages pressure will drop continuisly to about 75 then then the compressor will turn back off and the pressure will go back up. Am I in need of a new switch at the low or high side? Or is my compressor bad or what? Ambient temp at pressure measure was 100 degrees.
Old Jul 27, 2005 | 04:53 PM
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Also every few cycles it will click on and off very rapidly about 15 times then go back to the every 5 second cycling
Old Jul 27, 2005 | 09:28 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Sounds like low freon charge
Old Jul 28, 2005 | 12:03 AM
kyle folds's Avatar
Car: 89 Firebird
Engine: 355
Transmission: 700
Having only the low side readings gives us half the story. It is a stretch but a static presure of 120 at 100deg is possible, but the low presure switch won't turn off the comp at 75psi. Unless there is a buildup of other gasses in the system.
With only having half the facts I would say to recover and vaccum the system before recharging
Old Jul 28, 2005 | 10:10 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
My 93 escort had the same problem. It was low on freon, but before we filled it back up we vacuumed the system out and checked to see if it could hold it. It held for a half hour without dropping an inch. Filled it back up with R-134a and it works great now.
But I agree that there could be other problems.
jrdturbo
Mar 31, 2016 02:58 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
thejimsterz28
Sep 30, 2015 08:52 PM
anesthes
Sep 30, 2015 07:48 AM
ironbmt
Sep 27, 2015 06:00 AM
